Filters grayed out
COW Forums : Adobe Photoshop
Jeff Weit
Filters grayed out
on Aug 1, 2005 at 5:48:35 pm
I suddenenly have lost filters and effects on photoshop CS.
Only Blur is working the rest of the list is grayed out, I tried to uninstall and reinstall with the same results
Richard Harrington
Re: Filters grayed out
on Aug 1, 2005 at 5:58:37 pm
Well check your Image Mode CMYK vs. RGB
8 bit vs 16 vs. 32
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
Jeff Weit
on Aug 1, 2005 at 8:32:38 pm
Thanks for your quick response. Mode was set to 16bit. changed to 8bit and back in action
