saving cs2 animation frames
COW Forums : Adobe Photoshop
Andrei Lutic
on Jul 26, 2005 at 4:41:25 pm
Is it possible in photoshop cs2 when creating an animation using the animation pallette to save every frame on a separate image file (with one or few operations) without having to select every frame and save it. For example if I've created an animation that has 300 frames and I want to save them it'd be a real torment to save each at a time. Thx
Richard Harrington
Re: saving cs2 animation frames
on Aug 5, 2005 at 2:14:30 pm
File>Scripts>Export Layers to Files
You can also export a movie from ImageReady
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
Andrei Lutic
on Aug 8, 2005 at 7:02:10 am
