Rotate a Brush Shortcut?
COW Forums : Adobe Photoshop
Ragnar
on Jul 11, 2005 at 1:25:51 am
I did an archive search and didn't find an answer to this question. Is there a keyboard short cut for rotating a brush? That sure would come in handy instead of going to the Brushes palette and changing the angle.
Ragnar
Richard Harrington
Re: Rotate a Brush Shortcut?
on Jul 11, 2005 at 4:09:55 am
NOPE...
You can alwats look at the Edit>Keyboard Shortcuts command to check
You can though map brush dynamics is uding a tablet and angle can be driven by angle of pen
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
