Photoshop CS2 Video Preview not working.......
COW Forums : Adobe Photoshop
John Grilli
on Jul 10, 2005 at 8:50:37 pm
I just upgraded to Photoshop CS2 for it's video preview capability and I can't seem to get it to work, it just says "device not connected." I have an AJA IO box connected via firewire. I can view After Effects without a problem so I must be missing something. Can anyone help? Photoshop is the only program running. Thanks in Advance.
Richard Harrington
Re: Photoshop CS2 Video Preview not working.......
on Jul 10, 2005 at 9:13:01 pm
Make sure that Echo Fire isn't running as well
Also.. Apple video products interfere when in background.
Be sure firewire device is running and pwered before launching PS
Ensure you ahv QuickTime installed
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
grilliman
on Jul 11, 2005 at 3:55:27 am
I have done all of the above, anything else?? Do I have to have Tiger installed? I'm running Panther 10.3.9. Is there something else on the install disk that I missed?
Richard Harrington
on Jul 11, 2005 at 4:05:02 am
Tested it throuroughly for weeks.
Essentially
Make sure Apple Video Apps or Echo Fire isn't running
Make sure Deck is on
Choose the Video Prview one with teh elipse ... Set your options
Future Ones can use the other option (forgive me... on deadline for a book and to tired to walk over to the PS machine)
if still no work: May want to reinstall QuickTime First, then PSCS2
John Grilli
Re: Photoshop CS2 Video Preview not working...Answer!!
on Jul 11, 2005 at 10:36:19 pm
Thanks Richard for all of your help. Through hours of phone calls to Adobe and AJA, the problem lies in that it will output to a consumer DV source but not the AJA IO box. I was under the assumption that the Firewire output to the IO box would work. It does not work like the Adobe After Effects RGB output through firewire. I'm out of luck.
Richard Harrington
on Jul 12, 2005 at 2:07:23 am
Knew it didn't work with my Kona card.. but that it would with the AJA...
Would suggest Echo Fire then
Also.. check out the video actions in CS2 and let me know your thoughts
