Printing multiple contact sheets
COW Forums : Adobe Photoshop
jagaul
on Jun 14, 2005 at 2:08:25 am
I am attempting to print one each of 44 contact sheets which were created from a folder of wedding jpg files. For some reason I am only able to print one of the 44 at a time, then need again click print and go through the entire print setup again.
Any help would be greatly appreciated as I just don't have the time to set here through prining of all 44 one at a time.
Is it possible to batch this in some way.
Thank you in advance.
Judy
Richard Harrington
Re: Printing multiple contact sheets
on Jun 14, 2005 at 3:20:07 am
Use Acrobat to merge them all into one pdf
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro On The Spot & After Effects on the Spot
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.vasst.com
edit - produce - direct -
