Action skips step
COW Forums : Adobe Photoshop
Steven Thomas
Action skips step
on May 31, 2005 at 2:51:17 pm
I am working on a G4 and Photoshop CS. I have created an action that resizes an image, adjusts the levels and then applies an unsharpened mask. The problem is when I select a batch of images from the browser window and apply the action it skips the unsharpened mask step most of the time. I tried deleting the action and recreating it but the results are the same. Any idea what is going on? Thank you in advance.
Mike Gondek
Re: Action skips step
on Jun 6, 2005 at 5:52:12 pm
Are you sure that the unsharp mask is skipped, how do you know it is skipped. Images with larger resolution may need a higher radius for the effect to be noticeable.
The only way it would be skipped is if the checkmark to the left of the action is off. Toggle the dialog to on, and everytime the action is run, it will stop on the usnharp mask until you approve the settings.
