Discarding data outside the canvas
COW Forums : Adobe Photoshop
Brent Warwick
on May 31, 2005 at 2:45:43 am
Is there an easy way to discard data on a layer that is outside the size of the canvas? If I have a graphic layer I imported from a digital photograph, I can scale and position it as necessary, then I want to get rid of all the image data that lies outside the edge of the canvas.
Ideas?
-Brent
Filip Vandueren
Re: Discarding data outside the canvas
on May 31, 2005 at 2:57:55 am
You can simply "select all", then crop.
It will cut off all exces graphics on all layers.
If you want to do it on only 1 layer, I think the easiest way would be select-all, then Float the layer with control-J (or Command-J on mac)
It will create another cropped layer above the one you've selected, so you'll have to throw away the first one.
