Gradiant Transparent Effect on Graphic
COW Forums : Adobe Photoshop
Ryan Osika
on May 27, 2005 at 5:46:07 am
This seems like something that should be easy, but I can't for the life of me figure out how to do it. I have a solid graphic that I want to make into a "lower third" for a TV show. It needs to gradually become transparent from the left to the right side of the screen. How can I do this? Please help. Thanks very much.
Ryan
Jeff Cochran
Re: Gradiant Transparent Effect on Graphic
on May 27, 2005 at 6:02:21 pm
Create a gradient on an alpha channel
Go to the window pull down menu > Channels and create a new channel
Create a gradient from white to black. The white will be opaque. the black transparent.
However you save the file, make sure you save with alpha channels. If your saving as a Targa, save with 32 bit.
Good Luck
Jeff Cochran
http://www.jeffcochrandigitalartist.com/
