Combining Paths
COW Forums : Adobe Photoshop
Norman Walsh
Combining Paths
on May 20, 2005 at 12:36:22 pm
I have just started learning how to use the Pen tool.
So I have this image of a car which I want to copy into a different background, I adopted the following proceedure:
Using the Pen tool I created 5 paths one for the outside of the car the other four for the windows.
I had the Add to Path icon selected in the Options bar.
The reason I drew paths for the windows was because I wanted the background to show through.
Now my question is this: I can Control Click each path to turn it into a selection, so does that mean I have to drag the 5 selections seperately into the new background?
Or is there a way of combining them before moving.
Thanks a lot for any replies.
Norm
Jeff Cochran
Re: Combining Paths
on May 22, 2005 at 4:18:07 pm
You can do one of two things:
1. Hold down the shift key when you control click and click all the paths - this will make one selection from all the paths.
2. click on a path, copy, then click on another path and past - this will combine the paths
For future reference, you can draw all the elements of the path as one path and save yourself a step. The only time you'll run into problems is when two or more paths overlay each other. This will create a cut out in the selection.
Good luck
Jeff Cochran
http://www.jeffcochrandigitalartist.com/
Norman Walsh
Re: Combining Paths
on May 23, 2005 at 6:56:02 am
Thanks Jeff
Norman Walsh
