Batch Action to Covert EPS to Web Optimized jpeg
COW Forums : Adobe Photoshop
5x54u
on Apr 20, 2005 at 5:44:20 pm
Good Morning
I am on a quest for a Batch Action to convert eps to web optimized jpeg.
In addition I would like to maintain the same directory structure and image names. My directory structure is like this:
EPS
01
01.eps
02
01.eps
03 and so on up to 268
THe batch action would then need to create
jpegs
01
02
and so
Now I am sure this batch action does not exist. Could someone point me to a tuitorial that explains making your own batch actions in PS?
Thank you
Matt Sonberg
Re: Batch Action to Covert EPS to Web Optimized jpeg
on Apr 22, 2005 at 4:33:43 pm
Hey. I just figured this out the other day... if you open your history window by clicking on window and selecting history. Then select the "actions" tab within that window. You can create a new set by clicking on the little folder in the actions tab at the bottom. Then you'll see a record button to the left of that folder icon. That'll start recording your action. You may have to try to record the action a couple of times to get it exactly the way you want, but it's pretty easy. Then when you're ready to run a batch, open all of the files you need to modify. Go to File/Automate/Batch... In that window you'll see a drop down called: Action. Just select the new action you just created and make sure the rest of your settings look ok. That should do it. You may have to do a little trial and error to get everything right but that's the gist of it.
