Parent Child Compositing
COW Forums : Adobe Photoshop
Joost
on Apr 19, 2005 at 9:35:27 am
This may be a silly question for some of you experts, but OK, I will ask it anyway...
For video editing I work with Sony Vegas, and I love the parent-child compositing technique. I want to do something similar with still images in Photoshop. I see all the possibilities with layers in Photoshop, but I can't find a way to make a parent-child composite. Can anyone shed some light into my darkness?
For those who are not familiar with the term: in parent-child compositing two images (A and B) are mixed by way of a third image (C), which is a greyscale image. A white pixel in C means image A is visible, a black pixel in C means image B is visible. A grey pixel in C determines a mix of image A and B. This is in essense what I want with my stills.
Any help is very welcome. Thanks.
Joost
Kim Mackenzie
Re: Parent Child Compositing
on Apr 19, 2005 at 1:42:02 pm
This is the only way coming to mind - basically, use a positive of your Layer C as a mask on one layer, and a negative of it as a mask on the other.
Filip Vandueren
on Apr 20, 2005 at 10:30:50 am
Hi Kim,
If both layers were fully opaque to start with, there's no need to do it for the bottom layer too.
Because at a input value of 50% grey,
both layers would be at 50 % opacity, wich does not add up to 100%
And here's a faster way;
  • Get the three layers situated in your file
  • make only layer C visible
  • switch to channels and command-click on the RGB-channel -> turns the grayscale equivalent into a selection
  • hide layer C, show layer A & B
  • Select layer B (you should still sea the 'marchin ants' of your complex selection.
  • click on the layer-mask icon -> it automatically creates a layer mask that's equal to the current selection
If that's wrong, you should invert the mask.
Kim Mackenzie
on Apr 20, 2005 at 12:27:36 pm
Oh duh :) Yer right, of course.
Tim Neighbors
on Jul 9, 2015 at 1:45:30 am
I realize this is a very old post, but thought I'd share... select a layer in photoshop and press control+alt+G (on a PC). This will make it a child of the layer below. Make that child layer a multiply layer and put your mask in it with one of the images the parent (directly below), and the other below that. ...just another way to accomplish the same thing.
