Photoshop CS tools blocked
COW Forums : Adobe Photoshop
Joris Otten
on Apr 8, 2005 at 8:57:21 am
Hi all,
For some reason I can't use simple tools, like Brush, Eraser and Smudge on an apparently simple image. Even when I start with a plain white new document, PS just won't let me add pixels or otherwise tweak the image. The color mode or bit depth don't make any difference.
Strange thing is, that it IS possible to just Cut, Paste and Move areas of the picture. Hopefully it's just a matter of adding a 'tick' somewhere...
Many thanks in advance.
Joris.
jason white
Re: Photoshop CS tools blocked
on Apr 9, 2005 at 3:09:58 am
You may have a lock on your layer. Check in the layers palette, there's 4 locks located near the blending modes, make sure none of them are pressed down.
jason white
Joris Otten
on Apr 9, 2005 at 11:07:12 am
Thanks for your reply, Jason, but nope: none of the locks are pressed. PS simply won't let me brush or smudge. I'm starting to wonder if it will be easier when I just re-install the whole package.
Joris.
jason white
on Apr 9, 2005 at 7:58:29 pm
Hmmm, tried deleting the preference file? Hold command-alt-shift on start up and select yes. You've tried some other images too?
jason white
Joris Otten
on Apr 9, 2005 at 8:46:07 pm
Thanks again, but no changes. I removed the preference file and got a sort of 'clean' opening to PS, but still brushes didn't brush and smudges didn't smudge. There was no difference in using either an existing image or starting with a blank document. I've never heard of this kind of blocking before, so I figure something went wrong when I installed my package. Strange thing is that ImageReady works perfectly.
Bj
by
on Apr 10, 2005 at 9:08:05 pm
Take a look at "Brushes-Control"-Penpressure?!
Could be that simple, just change that one.
-Bjorn.
Joris Otten
Re: Photoshop CS tools blocked - fixed
on Apr 11, 2005 at 8:42:15 am
Yes! Got it, thanks mate! Indeed, it was just a matter of un-ticking the Shape Dynamics/Other Dynamics boxes in the brush prefs. How simple can it be...
Joris.
