converting PSD to a PDF file
COW Forums : Adobe Photoshop
Cesar
on Apr 6, 2005 at 8:59:22 pm
How do i convert a PSD file to a PDF? Is it as simple as just changing the file type when i save it or is there more to it.
Jeff Cochran
Re: converting PSD to a PDF file
on Apr 6, 2005 at 9:07:10 pm
Cesar
It really is pretty easy to create your PDF file
First, save the file out of Photoshop as a PDF, Now, if you double click on the file, it will open in Photoshop. So, what I do to make sure another user can open the PDF in Acrobat with out any trouble is, open Acrobat and use the OPEN command to open the file. SAVE AS and write over the original file. Now if you double click on the file, it will open Acrobat.
Jeff Cochran
http://www.jeffcochrandigitalartist.com/
David
on Apr 7, 2005 at 6:18:11 am
As Jeff said this is easy. However, what do you want to do with the PDF:
