Creating Powerpoint templates in Photoshop
COW Forums : Adobe Photoshop
Jason Wadsworth
on Apr 6, 2005 at 2:35:45 am
Is there a way to create Powerpoint templates (or even just backgrounds) in Photoshop. I just can't bring myself to use the cheesy Powerpoint standards anymore.
Jason
Richard Harrington
Re: Creating Powerpoint templates in Photoshop
on Apr 6, 2005 at 2:42:25 am
Templates no
Backgrounds of course...
Whole chapter on making backgrounds in my PS book.
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro On The Spot & After Effects on the Spot
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.vasst.com
edit - produce - direct -
Jeff cochran
on Apr 6, 2005 at 8:40:58 pm
Hi Jason
I'm with you there, I hate the PPT backgrounds
Backgrounds are easy for PPT from Photoshop. Create your file at 720 x 540 pixels, RGB color at 72 dpi. Create the background you want and save a copy as a JPEG.
In PPT, go under format to background. Look for the tab across the top labeled picture, then the button "select Picture" find your JPEG and import, hit OK, then either Apply or apply to all (hopefully self explanatory). There you have it, a custom background
Good Luck
Jeff Cochran
http://www.jeffcochrandigitalartist.com
Richard Harrington
on Apr 7, 2005 at 1:31:53 am
Build 1024X768
