RED Log and Transfer for R3D
COW Forums : RED Camera
Russell Lasson
on Apr 16, 2008 at 3:13:01 pm
A log and transfer window has been posted on the Red support page that will support transferring R3D files into FCP using ProRes.
It's a beta build, but will also allow applying looks that you've build in RedAlert to your footage.
-Russ
Russell Lasson
Kaleidoscope Pictures
Provo, UT
Ben Holmes
Re: RED Log and Transfer for R3D
on Apr 16, 2008 at 11:25:48 pm
Works pretty well for a beta. Excellent addition to RED workflow.
Ben
Jerry Hofmann
on Apr 19, 2008 at 7:15:04 pm
It's likely to be the most used workflow once it works with every format RED shoots... 16:9 doesn't work now, but it will. and 2:1 is working great now.
Jerry
Apple Certified Trainer
Author: "Jerry Hofmann on Final Cut Pro 4" Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Ben Holmes
on Apr 19, 2008 at 9:16:10 pm
The only drawback right now is the ingest downsizing 2:1 - so you can't ingest 2K at 2K. Would be nice with some of that 120fps footage everyone wants now!
I have assumed this was related to the proxies - as the maximum resolution of those is half size (the full size ones are just scaled up). Seems to be a limitation on the codec. It's on my wishlist for build 16..
Grahame - please?! Oops, went a bit REDuser there - too needy!
Ben
