Can't find XML file when exporting from timeline
COW Forums : RED Camera
Michael Swingler
on Jan 26, 2017 at 7:13:18 am
I'm trying to do a roundtrip from FCP7 to Redcine X and back to FCP7. I realize it's outdated software, but unfortunately this is an older project that was cut in FCP7. These are the steps I've taken and where I'm running into problems.
* Edited prores transcodes in FCP7 generated from original R3D files.
* Exported XML file
* Imported XML into RCX and relinked to R3D files.
* Exported Timeline (separated clips) as 4k Prores files with handles, and I check the Generate FCP XML in the Prores Setup options.
Here is where I run into the issue. All the clips are exported just fine, but there's no XML file. It's not in the export folder with the new clips or the project folder.
I'm assuming this XML file would allow me to import the timeline back into FCP7 with newly generated clips, unfortunately I can't find it anywhere.
Any suggestions? Or is this not the way to get the timeline back in to FCP7 with subclips?
© 2018 All Rights Reserved
