Audio record 50fps with red cam ?
COW Forums : RED Camera
Sata Pro
on May 12, 2015 at 1:47:22 pm
We will shoot a new serial in 4K. The delevery format which they ask from us is 3840x2160 in 50 fps. As I remember red was blocking audio in high frame rates. Is it still same? and/or which red models support this format with audio record on camera as well ???
Ercumend
David Battistella
Re: Audio record 50fps with red cam ?
on May 13, 2015 at 6:19:57 am
Could you be a bit more clear as to what your finishing specs are?
Are you looking to capture at 50FPS with a 50FPS timebase?
______________________________
http://www.bottegabattistella.com/blog/
Ercumend Kocana
on May 14, 2015 at 3:30:01 pm
Yes I will record, capture n playback all in 50fps. So I will need record audio to camera while I am shooting in 50 fps. Is it possible ?
