Convert files R3D to MOV with saved full original filename
COW Forums : RED Camera
ivan perekrestov
on Mar 19, 2014 at 1:23:14 pm
Hi all!
Tell me please, how to convert files R3D to MOV with saved full original filename, including the suffix _001..._002 etc.?
Example: original files A004_C018_03111V_001.R3D
Redcine-x render MOV in A004_C018_03111V.mov, while combining multiple files A004_C018_03111V_001.R3D;A004_C018_03111V_002.R3D etc.
I want to do export multiple files: A004_C018_03111V_001.mov;A004_C018_03111V_002.mov etc.
Ingrid Wood
Re: Convert files R3D to MOV with saved full original filename
on Aug 11, 2016 at 8:27:53 am
R3D (REDCODE RAW), is a proprietary video file format developed by Red Digital Cinema Camera Company. It is used as native recording format of Red digital cameras. It support 4K, 5K, even 6K captures. As a raw foramt, it stores each of the sensor's color channels separately, settings as white balance, exposure, and grading are appended to the file as metadata. REDCODE compresses video using wavelet technique, silimar in JPEG2000. This has some advantages over macro block based technique such as H.264, for example, it is very easy to get a low resolution version of the video.
Editing R3D files in Adobe Premiere/After Effects, Sony Vegas Pro, Final Cut Pro, etc is a quite easy job since R3D is compatible with these powerful editors.
To play R3D files, just download http://www.pdplayer.com/
To convert R3D files, just read: What is R3D file and how to convert R3D file.
