Date and time of transcoded file with REDCINE-X
COW Forums : RED Camera
Shermen Chan
on Jan 28, 2014 at 5:34:26 am
I try to transcode the raw file to Apple ProRes 422 PROXY with REDCINE-X, then I import it into FCP 7, but the clip doesn't show any time and date of the recording, is there any setting in REDCINE-X to output the proxy files with recording date and time included ?
Thank you
Ron Amborn
Re: Date and time of transcoded file with REDCINE-X
on Jan 28, 2014 at 8:04:51 am
Yep,
- In the Export Tab in REDcine-X, set up a new export preset. When the dialogue box shows up to create this preset, go under the tab "burn in." Under this tab you can "burn in" timecode, clip name, and a number of different options. You'll need to still set up your export format of course - Apple ProRes 422 Proxy.
Hope this helps! Let me know if you need anything else.
Sincerely,
Ron Amborn President
Maxx Entertainment Digital
21562 Newland Street
Huntington Beach , Ca 92646
Direct 714-374-4944
Cell 714-713-4492 Fax 714-374-3404
ron@maxxdigital.com
http://www.maxxdigital.com
