Trouble with rendering R3D file. How can I recover that file?
COW Forums : RED Camera
Lars Olav Seim
on Jan 17, 2014 at 11:35:30 am
I have one R3D files that causes both Monkey Extract and RedCine to crash about halfway in the render process. The record process for this file (RED Epic) stopped because of full card, so I guess that´s the reason (it was not stopped with the record button). I can preview the file perfectly fine in RED Player.
What is the easiest way to recover this file?
David Battistella
Re: Trouble with rendering R3D file. How can I recover that file?
on Jan 17, 2014 at 3:15:12 pm
Lars,
I have never tried this, but you might want to use the TRIM R3D function in RECINE X to create two NEW clips from the one file. Perhaps in this way to can discover where the data was corrupted.
You could then try to render the TRIMMED CLIPS and if they do, reconnect them in another app.
Battistella
______________________________
http://www.davidbattistella.com
james Lackleter
on Jan 19, 2014 at 6:50:18 pm
Try opening it in other applications, Resolve for starters, After Effects, etc. Call Red they'll be able to help, but try resolve first.
