Thunder Bolt Mobile Rocket Upgrade by Maxx Digital
COW Forums : RED Camera
Ron Amborn
on Jan 10, 2014 at 10:34:10 pm
Mobile Rocket TB owners
Maxx Digital will be offering an upgrade path for your exsisting Thunder Bolt 1 systems. It will be under 100.00 upgrade fee and will be available in late February.
Sincerely,
Ron Amborn President
Maxx Entertainment Digital
21562 Newland Street
Huntington Beach , Ca 92646
Direct 714-374-4944
Cell 714-713-4492 Fax 714-374-3404
ron@maxxdigital.com
http://www.maxxdigital.com
David Battistella
Re: Thunder Bolt Mobile Rocket Upgrade by Maxx Digital
on Jan 14, 2014 at 9:20:28 am
Hi Ron,
Is this an upgrade to thunderbolt 2.
It doesn't say on your site whether this box supports the RedRocket X which I believe requires additional power.
I see its compatible with RedRocket Legacy but will it be forward compatible to the New REDRocket.
David
______________________________
http://www.davidbattistella.com
Matt Stone
on Jan 14, 2014 at 5:52:19 pm
Hey David,
Yes this is an upgrade to Thunderbolt2 for our existing Mobile Rocket Thunderbolt users that purchased our product with Thunderbolt1 connectivity.
Our Mobile Rocket Thunderbolt WILL support the RED ROCKET-X physically and electronically. We designed the expansion chassis to have internal power cables within the unit that will power the RR-X with a LP4 to 6-Pin PCIe Video Card Power Adapter.
Matt
Matt Stone
3189 Redhill Ave. Unit B
Costa Mesa, CA 92626
Telephone:(714) 374-4944
mattstone@maxxdigital.com
Ron Amborn
on Jan 14, 2014 at 6:31:24 pm
David
Yes the upgrade on the Mobile Rocket TB is for TB II. And yes it will power Red Rocket X. We have tested it here and it works great. As we know from testing , TB II does not go as fast as the specs say in real world but it is faster than TB I. We continue testing and looking for ways to optimize speed with the New Mac Pros. Stay tuned .....
Sincerely,
Direct 714-374-4944
ron@maxxdigital.com
David Battistella
on Jan 14, 2014 at 11:48:12 pm
Thanks Ron,
I'm sure you guys built a rock solid enclosure there and I know your relationship with Red goes back to the start of the rocket. Are you making an effort to build these enclosures any quieter? I have not "heard" the new RRX, but if the box is loud maybe it would be good to after some longer TB cables along with this setup.
Does the enclosure provide fast enough PCI lanes for the RRX? Or does RCX still give the message that it the slot does not allow the card to work at full speed.
battistella
Matt Stone
on Jan 15, 2014 at 1:51:49 am
Hey David,
We have been testing different fans to see if there is a quieter solution, but the RRX is going to be a powerful card. In turn it will most likely produce more heat than the previous card, so fans will be needed to keep this card cool. On the current Mobile Rocket Thunderbolt with gen.1 TB connectivity, there are no errors that come up when starting RCX. It sees the card in an 8x slot. Stay tuned to see how it behaves with a TB2 enclosure.
Matt Stone
David Battistella
on Jan 15, 2014 at 1:38:16 pm
Great news Matt,
This combo looks great and very promising.
Battistella
gary adcock
on Jan 15, 2014 at 3:21:37 pm
[Ron Amborn] "TB II does not go as fast as the specs say in real world but it is faster than TB I. "
Ron,
the rated specs say that TB2 should top out at right around 1.4GBps, and I have seen data speeds as fast as 1.365GBps, but I expect these to increase as TB2 gets more widely adopted.
gary adcock
Studio37
Post and Production Workflow Consultant
Production and Post Stereographer
Chicago, IL
Follow my blog at http://www.garyadcock.com
Or follow me on Twitter
@garyadcock
Ron Amborn
on Jan 15, 2014 at 8:02:53 pm
Gary
Agreed on your speed numbers . What I am seeing is people saying 2.0 and not 1.4 which you have confirmed is real world numbers. The hype of TB 2 as you said is not quite there yet.
Sincerely,
Direct 714-374-4944
ron@maxxdigital.com
gary adcock
on Jan 15, 2014 at 11:48:37 pm
[Ron Amborn] "Agreed on your speed numbers . What I am seeing is people saying 2.0 and not 1.4 which you have confirmed is real world numbers"
Ron,
With the theoretical limit of Thunderbolt 2 at approximately 1.6 Gigabytes per second. > Gbps x 0.8 = GBps< it is really hard to go much faster than that, most of the issues I have seen with devices so far are either as a limit of the caching structure on storage or as a physical limitation of the designs
gary adcock
Studio37
Chicago, IL
@garyadcock
