 | REDCINEX color grading send back to FCP7 problem
on Dec 8, 2013 at 8:28:49 am |
Hi guys,
this is my first time operating FCP - Red workflow,
so I transcode footages to Proress LT, and edit in FCP 7
(R3D raw footage's file names are remained the same, but I sync those Proress files and rename them)
export a XML, import it in RedcineX
color grading there,
then export a FCP XML
trying to import back in FCP7,
but the system says " Non-critical errors were found while processing an XML document"
what did I do wrong ?
I've tried many many times
thanks
 | Re: REDCINEX color grading send back to FCP7 problem on Jan 4, 2014 at 11:40:23 am |
There was a program called clip finder that was an absolute dream for this workflow, but I am not sure you can still get it. If you can get your hands on a copy it's well worth it.
David
______________________________
http://www.davidbattistella.com
