Changed menu output priority.. can't get it back!
COW Forums : RED Camera
Tom Barton-Humphreys
on Dec 2, 2013 at 3:18:52 pm
Hi there
I was trying to change the output to my external monitor from HDMi to HDSDI. For some reason it would not accept that I wanted video outputting via SDI.
I changed the priority output from the viewfinder to the SDI, however I now have no way of controlling the menu's. I can see the video out put via the EVF, but I can't control/select or even see which menu is highlighted via the EVF or the external monitor.
Any ideas on how to change it back?!
Many thanks
Tom
David Battistella
Re: Changed menu output priority.. can't get it back!
on Dec 2, 2013 at 3:25:29 pm
Might be a good idea to save your current settings and then do a restore and a restart to the camera. This resets everything to factory default.
David
______________________________
http://www.davidbattistella.com
on Dec 2, 2013 at 3:34:17 pm
How do I save current settings with no menu control?
Cheers
Tom
David Battistella
on Dec 2, 2013 at 3:51:17 pm
Have you tried double tapping the display to bring the menus back?
David
on Dec 2, 2013 at 4:26:15 pm
I have a cheap external monitor - non touch screen - and a bomb EVF
David Battistella
on Dec 2, 2013 at 5:55:01 pm
Power down.
Press and hold the startup button for at least 15 seconds when you reboot.
That should get you back to factor defaults.
David
on Dec 6, 2013 at 2:17:19 am
Worked perfectly! Now just to reset all my shortcuts... Thanks.
David Battistella
on Dec 7, 2013 at 10:19:05 pm
Good to hear.
Thanks for reporting back, that way other users know that it worked.
David
