RED in Speedgrade
COW Forums : RED Camera
Nina Sargsyan
RED in Speedgrade
on Oct 19, 2013 at 9:39:46 pm
I have a project in Premiere that consists of Red Epic 5k shots, now I've downscaled them to 2k and made an EDL and went to Speedgrade. In speedgrade Im not being able to relink the media, I keep getting "Frame Index Out of Range", and on the footage in the Speedgrade timeline it shows -1527, the timecode of the shot is 17:40:15:01-17:41:02:14. Can anybody give some insight into this issue, it would be appreciated.
Angelo Lorenzo
Re: RED in Speedgrade
on Oct 19, 2013 at 11:35:29 pm
In Speedgrade, make sure both your timeline FPS and your FPS settings under Settings > Editing match your EDL before trying to import and link.
Angelo Lorenzo
Need to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services - Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire - The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Can your post production question fit in a tweet? Follow me on Twitter
Nina Sargsyan
on Oct 19, 2013 at 11:39:24 pm
Hey Angelo, thanks for the reply. I have double triple checked the settings,
Sequence settings in Premiere are 24fps, so is my footage
Speedgrade settings are 24fps Base Timeline.
I even re installed speedgrade but the issue still persists, it cant be the footage cause when I just drag the footage separately in speedgrade I have no issues, and when I did a DPX render out of Premiere of the same sequence with the same footage I had no issues.
