Which R3D File do you use as your master clip when there are more than Two in the RDC Folder. I have a folder A005_C001.RDC that contains 2 R3D files that are the same except in size. Which one do i use when I am editing in premiere. When I
COW Forums : RED Camera
Charles Willis
on Oct 16, 2013 at 3:14:23 pm
Which R3D File do you use as your master clip when there are more than Two in the RDC Folder. I have a folder A005_C001.RDC that contains 2 R3D files that are the same except in size. Which one do i use when I am editing in premiere. When I import the folder it imports both clips
Eric Santiago
Re: Which R3D File do you use as your master clip when there are more than Two in the RDC Folder. I have a folder A005_C001.RDC that contains 2 R3D files that are the same except in size. Which one do i use when I am editing in premiere. Wh
on Nov 5, 2013 at 1:11:54 pm
Just point at folder and import.
Its the one that has the *.R3D extension.
I wouldnt screw around with the file/folder structure.
David Battistella
on Dec 3, 2013 at 9:16:47 am
They are all the same file.
Multiple spanned files are created (2GB files size each) to create one single R3D clip.
It's completely normal.
David
______________________________
http://www.davidbattistella.com
