Epic footage with low green clip
COW Forums : RED Camera
Scott Smith
on Oct 2, 2013 at 8:41:31 am
Footage I'm grading from Red Epic has a significantly lower green clip than the red and blue (which match), thus, any clipped or burned out highlights go magenta. No matter what gamma settings used, the green is cliped significantly lower. The only fix I have is to clip the red and blue channels to match. This is my first Red project, is this a common problem? Is there a camera adjustment I should let the shooter know about?
Bruce Greene
Re: Epic footage with low green clip
on Oct 23, 2013 at 11:33:44 pm
I maybe late, but ask the DP to set ISO at 500 or above.
Varicam/Steadicam Owner
Los Angeles, CA
http://www.brucealangreene.com
