RED CINE X slow transcode
COW Forums : RED Camera
Clay Stanton
on May 22, 2013 at 5:21:36 am
Hi - transcoding EPIC-X footage to ProRes 422 (1080).
I am really surprised to find that Red Cine X encode takes over TWICE as much time as regular FCP 7 Log and Transfer (1 minute clip: 10mins encoding time on FCP, 24 mins encoding time on RCX)
From what I've read and heard Red Cine X is supposed to be faster, right? Any ideas please? (I have Redline [software only] enabled).
Jason Flor
Re: RED CINE X slow transcode
on May 25, 2013 at 6:43:36 pm
Red makes you shell out another 5 grand for the Red Rocket card if you want faster speeds. Best to do all your color correction filling the bin as you go. Then at the end of the day transcode everything in the bin overnight.
Angelo Lorenzo
on May 26, 2013 at 4:41:14 am
In software only mode, remember that you can also transcode multiple files at once. If your disks can handle the throughput then this is a common way of speeding the process up as a whole.
Angelo Lorenzo
Need to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services - Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire - The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Can your post production question fit in a tweet? Follow me on Twitter
Colin Hubick
on May 27, 2013 at 5:52:31 pm
With regards to FCP log and transfer vs. Red Cine. FCP Log and transfer only outputs at half res vs. Red Cine which is likely full res. This would account for the time differences between the two.
