Red Epic 5K down convert for premiere pro cs6
COW Forums : RED Camera
Jorge Hernandez
on May 7, 2013 at 9:51:20 pm
I just got delivered some footage from the camera men that shot an interview with the Red Epic, problem is that it was shot in 5K. I have a macpro tower and editing on Premiere Pro CS6. I just downloaded redCineX and I'm trying to figure out how to downgrade the quality to regualr HD. How can I export this to Proress or any other format that can work on my machine without stutters. Thanks in advance for any help.
Angelo Lorenzo
Re: Red Epic 5K down convert for premiere pro cs6
on May 8, 2013 at 6:24:03 am
You can do one of a few things. First make sure your RED Importer plugin is up to date in Premiere
Next read the Redcine-X manual - it is included with the Redcine-X install.
You can either edit directly in 5K in Premiere if you turn the quality of the program monitor down to 1/8 or 1/16 or you can, as you plan, convert the footage and edit "offline" in something like 1080HD.
The latter will be easier and the Redcine-X manual will teach you the export process.
Angelo Lorenzo
Need to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services - Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire - The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Can your post production question fit in a tweet? Follow me on Twitter
© 2018 All Rights Reserved
