Can See RAW RED footage in REDCINE, but not in Premiere CS6
COW Forums : RED Camera
Chris Joslin
on May 6, 2013 at 8:02:43 pm
Hi all,
Had a quick question. We just shot a commercial in 4K RAW on the Scarlet. When I bring the files into Premiere they edit fine, however SOME OF THEM are not RAW. They're a bit crunched actually. But when I view the same files in REDCINE-X Pro, all the RAW data is there. Any ideas about what's missing in Premiere?
-C
Angelo Lorenzo
Re: Can See RAW RED footage in REDCINE, but not in Premiere CS6
on May 8, 2013 at 6:26:51 am
http://labs.adobe.com/technologies/redepic_importer/ make sure your RED importer plugin is up to date.
If any adjustments were made in Redcine after the footage was loaded into Premiere, then you need to reload RED RAW settings per-file in Premiere or use my tool http://www.fallenempiredigital.com/blog/2012/07/29/batch-reload-redcine-x-r... This can also be the cause as to why you may see two different versions of the same file.
Angelo Lorenzo
Need to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services - Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire - The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Can your post production question fit in a tweet? Follow me on Twitter
