Comparing Before/After Grading in Redcine-x Pro
COW Forums : RED Camera
Nicholas Rademacher
on Apr 19, 2013 at 8:20:13 pm
Is there a way to disable the grading in Redcine-x like there is in Speedgrade? In Speedgrade you can press Numpad 0 and it will show you what the original image looked like so you can compare the two, but I can't figure out if there's a way to do it in Redcine-x. Or if theres's a way to do a side by side comparison.
Justin O'Neill
Re: Comparing Before/After Grading in Redcine-x Pro
on Apr 19, 2013 at 9:28:10 pm
The closest option you have is the M & D (Metadata and Default) to the right of "Look Manager" on the right column. Pressing the "D" will go back to the defaults while "M" will go back to the metadata set in the camera. Looks like this doesn't reset Alchemy or Filmlook though...
Angelo Lorenzo
on Apr 19, 2013 at 9:28:29 pm
Currently, not so far as I know. Save two states as look presets and use "Apply to clip in viewer" and use the preview button. The look preset usually has a "Meta" preset which will reverse the footage to the settings it was recorded with in camera.
Angelo Lorenzo
Need to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services - Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire - The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Can your post production question fit in a tweet? Follow me on Twitter
