RedCine-X pro sees wrong camera in metadata - imports monochrome
COW Forums : RED Camera
Susan Dempster
on Mar 14, 2013 at 6:35:26 pm
This is my first time working with Red files - so my apologies for ignorant questions!
I downloaded RedCine-X Pro (build 17). When viewing files in the Red Player or the Cine-x app, all the clips are grayscale. The metadata says it was shot with the Epic-X Monochrome, which would make sense... except that it was shot with Epic-X (non monochrome version). I installed the software on another box, same problem. I uninstalled and re-installed using build 15 - still b&w.
The person who filmed this can view in build 15 of the software and both the color and metadata display correctly.
Any ideas? I'm at a loss for what to do next...
Thanks in advance!
David Battistella
Re: RedCine-X pro sees wrong camera in metadata - imports monochrome
on Mar 15, 2013 at 11:22:07 am
Maybe go to the website and download build 15 and try that?
http://www.red.com/support
You can get legacy versions of REDCINE X there.
David
______________________________
The shortest answer is doing.
Lord Herbert
http://www.davidbattistella.com
Susan Dempster
on Mar 15, 2013 at 1:05:52 pm
I tried build 15 and 17 on two different mac pros - same grayscale issue.
David Battistella
on Mar 15, 2013 at 1:55:19 pm
Can you create an R3d snapshot and email it to
david (dot ) battistella (at) gmail (dot) com
and I will have a look on my system?
TO create the snapshot, stop on any frame and hit the little r3d snapshot file in the bottom left corner of the viewer.
David
Lord Herbert
Susan Dempster
on Mar 15, 2013 at 2:30:54 pm
I posted one here:
5653_a024c0970206wo.0000000s000f.r3d.zip
Angelo Lorenzo
on Mar 16, 2013 at 9:39:03 pm
It shows as greyscale in Redcine-X build 17 on Windows 8. It shows in color in After Effects (this uses the RED SDK, pieces of RED's software's code).
I would uninstall all versions on Redcine-X on your system to make sure there are no shared bits of code. I'd roll back further and try build 14.
Has the camera had its firmware updated? Was it from a rental house... makes me think it was flashed incorrectly if it's not a bug inherent of Redcine X.
I haven't see this before with my Epic for Redcine-X build 17, and we shoot regularly.
Angelo Lorenzo
Need to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services - Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire - The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Can your post production question fit in a tweet? Follow me on Twitter
Susan Dempster
on Mar 18, 2013 at 12:51:36 pm
Hi Angelo,
I don't know how recently the camera firmware has been updated, but no, it was not from a rental house.
I downloaded a trial of Adobe Premiere CS6. Remarkably I see color in Premiere, though still not in the Red software! Looks like I'll be purchasing the license for Premiere this week - so glad to have found something that works!
