Converting Rec709 stills so they display correctly on iPad (AdobeRGB)
COW Forums : RED Camera
Filip Dobosz
on Feb 22, 2013 at 5:03:50 am
Is there a way to easily convert the TIFF stills I pull from RedCineX so that what i correct in (Rec709) looks like what i do on an iPad (AdobeRGB)? I put stills into aperture to send them to iPad.
Angelo Lorenzo
Re: Converting Rec709 stills so they display correctly on iPad (AdobeRGB)
on Feb 23, 2013 at 12:31:33 pm
Where are you getting the fact that the iPad uses AdobeRGB?
iPads have, until recently, been very narrow gamut devices.
From the introduction of the iPad 3, the screen's color coverage is close to but not quite the entire sRGB gamut. Rec 709 uses the same color primaries and white point as sRGB but has a more tuned gamma curve for darker viewing environments; these differences make Rec 709 and sRGB pretty interchangeable when it comes to non-color-critical viewing.
I'm not sure what the iPad 4 is rocking but chances are it's similar to the previous generations to keep screen costs low.
Keep your stills as sRGB/rec 709.
http://www.anandtech.com/show/5688/apple-ipad-2012-review/4
http://dot-color.com/2012/03/20/apples-new-ipad-display-what-does-44-more-c...
Angelo Lorenzo
Need to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services - Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire - The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
