Aerials and rolling shutter
COW Forums : RED Camera
Charles Binn
on Jan 11, 2013 at 12:26:18 pm
we had to do some aerials in an harsh environment. Micro light plane, no Cineflex, a lot of vibrations. Red Epic camera. 160fps or more. Shutter set to 90 degrees.
We ended up in footage with serious rolling shutter artifacts.
Any idea how to fix it? I tried AE rolling shutter and warp stabilizer. Couldn’t fix it.
One sample is on mydrive.ch
User: aerial@CharlesBin
Password: aerial
Does anyone have an idea how to fix it?
Thank you
Charles
David Battistella
Re: Aerials and rolling shutter
on Jan 16, 2013 at 10:34:31 am
I tok a look at this footage and I can't see how it can be fixed.
perhaps 160 was a bit excessive. if you wanted to remove vibration 48 FPS might have been enough, put if the camera vibrates that much then I would suggest another flying option.
David
______________________________
The shortest answer is doing.
Lord Herbert
http://www.davidbattistella.com
