Redcine x pro not transcoding prores
COW Forums : RED Camera
Dan Saberi
on Sep 11, 2012 at 6:25:53 am
This is my first time working with red footage.
I'm trying to transcode the r3d files to prores.
With my other programs like adobe encoder i have prores codec but not in redcine x pro.
In fact I have maybe 5 codecs to choose from in redcine x.
Do I need to download prores or is there a way to check whether i have it?
Its a noob question but im not good with codecs.
David Battistella
Re: Redcine x pro not transcoding prores
on Sep 11, 2012 at 7:28:07 am
If you are on a MAC and you have FCP installed, then you have prores.
IF you are on a PC, I do not think it is possible to render prores.
Prores 422 HQ is fine for most situations, you can set up a render preset in the export pane of Redcine X.
you can also download the codecs here:
http://support.apple.com/kb/DL1396?viewlocale=en_US&locale=en_US
David
______________________________
The shortest answer is doing.
Lord Herbert
http://www.davidbattistella.com
