REDCINE vs FCP Log & Transfer
COW Forums : RED Camera
Brandon Morris
on Feb 23, 2012 at 1:56:44 am
Is RedCine 64bit?
I read somewhere online that FCP Log and Transfer can be faster than RedCine transcoding, any advice?
Brandon Morris
Co-owner/Creative Director
http://www.fugostudios.com
RED Scarlet, Canon T2i, Panasonic HPX-170
Nikon Primes
Mac Pro 12-core 64GB RAM (2011)
Mac Pro 8-core 12GB RAM (2008)
Mac Pro 4-core 8GB RAM (2006)
13" Macbook Pro (Mid 09) 8GB RAM Lion
Stuart Ferreyra
Re: REDCINE vs FCP Log & Transfer
on Feb 23, 2012 at 2:23:27 am
Yes, FCP Log and Transfer is faster but it adds its own gamma curves. FCP Log and Transfer should only be used for offline editing. If you are trying to use it for both offline and online, I wouldn't recommend it. If you are going to do an online using ProRes (as opposed to using the raw files), it will always be better to do it in RedCine (with or without a Rocket card).
Stuart Ferreyra
Professional Colorist, Finisher, Online Editor.
http://www.timecodemultimedia.com
TIMECODE MULTIMEDIA
- Professional and Affordable Post for Indies.
- ProTools Sound Design, Sound Editing and Sound Mixing.
- Color Grading, Finishing and Mastering for TV and Film.
- DaVinci Resolve SD, HD, SR, RED, ALEXA, DSLR.
- SD, HD, SR Deck Rentals + Edit and Finishing Suites Rentals.
Brandon Morris
on Feb 23, 2012 at 2:45:58 pm
Is it not possible to correct the curve with a LUT or standard color correction curve?
Brandon Morris
Nikon Primes
Matt Gerard
on May 10, 2012 at 4:30:40 pm
Yes, but the point is that you aren't correcting the RAW files, you are color correcting the PRORES files. So depending on how far you are pushing your curves/corrections you won't get the latitude of adjustments that you would get with the RAW files, hence the reason for shooting RAW. Alot of my projects are Shot with a "look" in the the camera that gets us close to what we want the final to be, then small tweaks are done in AE or FCP, with the PRORES files, so we aren't pushing the PRORES files to hard when correcting.
So, it depends on how much flexibility you want in correcting the files after edit. If you will be doing wild and crazy stuff, best to do that in RCX, if not, FCP or AE corrections on PRORES files will probably be fine. Even then, you can always go back to the RAW files on a shot by shot basis as needed.
And as always, run a test to see what gives you what you need. Maybe the speed is an ok tradeoff for latitude in your grading process, maybe not.
Matt
Its more fun to ride a slow motorcycle fast than a fast motorcycle slow...
Andres Delgado
on Mar 19, 2012 at 12:27:55 am
I always use RedCine-X PRO, but in FCP L&T you cannot correct your footage using the .R3D, i recommend you use a workflow using QT proxies. is the best way to save time and hard disks space!!!
