default 180 degree shutter speed
COW Forums : RED Camera
Charles Binn
on Feb 16, 2012 at 5:55:54 pm
When I change the frame rate I always have to edit the exposure time. Is there any possibility to set the shutter to 180 degrees as a default for all frame rates?
Charles
gary adcock
Re: default 180 degree shutter speed
on Feb 16, 2012 at 6:01:19 pm
[Charles Binn] "When I change the frame rate I always have to edit the exposure time."
Yes that is correct- more frames per second require more light striking the sensor- beyond 120FPS you need a lot of light to get the same look.
" Is there any possibility to set the shutter to 180 degrees as a default for all frame rates"
that would be great if it were not for the physics involved. At 120fps and beyond you don't use a shutter at all- mainly because it cannot refresh fast enough.
(this is the same on film cameras - after a certain point the shutter is effectively off)
gary adcock
Studio37
Post and Production Workflow Consultant
Production and Post Stereographer
Chicago, IL
http://blogs.creativecow.net/24640
follow me on Twitter
@garyadcock
Charles Binn
on Feb 16, 2012 at 6:09:15 pm
Sorry. Found the entry in "modes".
Charles
David Battistella
on Mar 3, 2012 at 9:16:44 am
I think you are refereing to absolute shutter vs relative shutter mode on the red. One stays fixed and the other automatically adjusts when you adjust the framerate.
______________________________
The shortest answer is doing.
Lord Herbert
http://vimeo.com/battistella
