Shooting 5k with Red Epic and cropping to 2:39:1 aspect ratio
COW Forums : RED Camera
Raymond Tarry
on Dec 28, 2011 at 5:17:30 pm
Hello, I've seen a picture of Red Epic's frame guide that lists the 2:39:1 aspect ratio as an option. Does this mean that instead of using expensive anamorphic lenses to achieve 2:39:1 theatrical ratio, you can shoot 5k with round lenses, compose in camera for 2:39:1 and crop in post to the 2:39:1 ratio?
If so, it seems like this a step forward in technology.
Thanks - Craig
David Battistella
Re: Shooting 5k with Red Epic and cropping to 2:39:1 aspect ratio
on Jan 4, 2012 at 1:57:54 pm
Only anamorphic glass will give you the characteristic anamorphic look and streak flares.
you could try to "fake it" by using the camera guides as a crop and then also using a streak filter on the lens. You'd be loosing some picture information. I think those guides are there to help when you are shooting with anamorphic glass.
David
______________________________
The shortest answer is doing.
Lord Herbert
http://vimeo.com/battistella
Raymond Tarry
on Jan 5, 2012 at 12:13:49 am
Thanks David, I appreciate it - Craig
