false colors
COW Forums : RED Camera
samer mahmoud
false colors
on Dec 24, 2011 at 2:02:06 am
just got a project shot on red one (2K),its showing bad color and over exposure when playing the quictike files or importing it to FCP7, client told me it was not like that on set.
so i have to import it as native then in Color 1.5 to turn off the Red settings and work on the flat image from A to Z.
how can i fix that thing, so i can import RED files into FCP as 422HQ with the correct color they had on set??? since its too slow to edit native when client is asking for too many transitions and filters, using proxy and cinema tools to conform is not an option :(
David Battistella
Re: false colors
on Dec 30, 2011 at 4:37:58 pm
Which Camera version?
What build was the footage shot on?
Do you have RCX 9 installed on your system?
Answers to these questions couls help me help you.
David
______________________________
The shortest answer is doing.
Lord Herbert
http://vimeo.com/battistella
samer mahmoud
Re: false colors
on Jan 10, 2012 at 6:24:57 am
not sure about the version and im sure the client doesnt know it, but the same problem keeps going on, even with another source.
what is the RCX9 ? u mean red cine? yes i have it
David Battistella
Re: false colors
on Jan 10, 2012 at 12:30:12 pm
It's hard to answer without knowing the camera EPIC, Scarlett or RED ONE MX.
If you open the files in REDCINE X, the metadata there will tell you what camera it was shot on and it will also show you the exact settings that were used on set.
Can you contact the DIT?
Was there a person in charge of copying the footage?
What is your planned workflow?
David
Lord Herbert
samer mahmoud
Re: false colors
on Jul 26, 2012 at 11:18:00 pm
it was RED ONE, they did copy the entire card contents in new folders,
im transcoding to ProRes 422HQ. as i said the generated files playing fine on desktop when usig Quick time player, or when using the video player comes with Matrox MXO2 rack, i monitor audio normally on the speakers connected to the break out box. only in FCP and Prm. the audio is being noisy,
NB, can i send u a smalpe? about 5 seconds ... if yes, how?
