Trying to send to Color from FCP using Cinema Tools and EDL per Red white paper
COW Forums : RED Camera
Warren Eig
on Nov 14, 2011 at 10:22:09 pm
Has anyone gotten and exported EDL from FCP 7 and a CinemaTool Data base to reconnect in Color?
I did everything to a "T" per the Red workflow white paper RED emailed me and all the shots come in labeled "AUX" and there is no picture.
Has anyone gotten this to work? I tried calling Red here in California, but no one picks up it all just voice mails
Warren Eig
O 310-470-0905
email: warren@babyboompictures.com
website: http://www.babyboompictures.com
http://www.babyboompictures.com/BabyBoomPictures/F5_Director_Cut.html
http://www.babyboompictures.com/BabyBoomPictures/AFX.html
http://www.babyboompictures.com/BabyBoomPictures/KnitWits_Movie.html
http://www.imdb.com/name/nm0251670/
EDITING REEL: http://www.babyboompictures.com/BabyBoomPictures/Editing_Reel.html
TITLE DESIGN: http://www.babyboompictures.com/BabyBoomPictures/Titles_Reel.html
Alex Elkins
Re: Trying to send to Color from FCP using Cinema Tools and EDL per Red white paper
on Nov 18, 2011 at 2:50:57 pm
Wow, I'd forgotten about the ELD + Cinema Tools method. It's been a few years since I used it but it definitely worked. I'll test again and see if I can still make it work.
Were you cutting with the proxy files or transcoded files?
Alex Elkins
Twitter: @postbluetv
http://www.PostBlue.tv
View Post Blue showreel
Shot on RED @ 100fps, Post on FCP/Color: Capoeira Film
Alex Elkins
on Nov 18, 2011 at 4:11:25 pm
Hi Warren,
I can confirm that the Cinema Tools method is still working for me. My tested workflow is as follows:
1. Edit with transcoded files.
2. Export Batch List and EDL from FCP
3. Import Batch List into a Cinema Tools database.
4. Connect to raw R3D files
5. Open EDL in Color and use Cinema Tools database at the Import Clips location.
I have a feeling you might be missing out Step 4 - connect the database to the raw files.
Alex Elkins
Warren Eig
on Nov 18, 2011 at 4:15:27 pm
I did it according to Red's workflow PDF. It is vastly different from what you describe.
Warren Eig
O 310-470-0905
David Battistella
on Nov 18, 2011 at 4:17:58 pm
Consider the CLIPFINDER XML workflow.
Silky smooth in FCP 7 and Color.
David
______________________________
The shortest answer is doing.
Lord Herbert
http://vimeo.com/battistella
Chris Borjis
on Nov 23, 2011 at 11:00:54 pm
David would that also work with Epic footage?
