What's the proper resolution to edit in when finishing at 4k?
COW Forums : RED Camera
Burke Lewis
on Sep 27, 2011 at 11:31:33 pm
I'm working on a project that is my 2nd time editing RED footage. The first time we finished it at 1080 with little color correction so we just used the Prores files we created to edit with to export the final video.
However, this project is intended for cinema and needs to be finished at 4k. I've already made 1080p Prores proxies. At this point, I just need to know how to finish in 4k. I've read all the different methods of relinking to the original R3D's, but I just want to make sure that it's ok to edit in 1080 and finish in 4k...or if I should have made 4k proxies to edit with.
Any suggestions are helpful.
David Battistella
Re: What's the proper resolution to edit in when finishing at 4k?
on Sep 28, 2011 at 8:20:44 am
By using the scoll wheel or search function you would find that about five threads down this topic is covered in great detail and fantastic solutions are revealed.
http://forums.creativecow.net/readpost/242/5533
David
______________________________
The shortest answer is doing.
Lord Herbert
http://vimeo.com/battistella
Mike Most
on Sep 28, 2011 at 10:23:08 pm
I would add that nothing "needs" to be finished in 4K. The vast, vast majority of theatrical releases are in 2K, and the vast majority of DI's are still being done in 2K. Wanting to finish in 4K and "having" to are two different things.
David Battistella
on Oct 2, 2011 at 10:34:23 am
This is very good advice from Mike.
It also mean you will use 1/4, yes 1/4 the data (not half) that you would in a 4K online.
Playback, drivespace , etc all need to be optimized for 4K and it's mostly top facilities that are prepared for this.
David
Lord Herbert
boyce uboh
on Feb 6, 2012 at 9:23:20 pm
I just saw some 4k footage on youtube and they looked great.I am wondering how they were able to finish in 4k ? I did like to finish in 4k and upload a footage to youtube.i have a red scarlet,Autodesk smoke on a fast Mac with red rocket.
