Basic questions about FCP, RED, and Cinema Tools
COW Forums : RED Camera
Kathryn Cates
on Aug 17, 2011 at 3:26:40 am
Hello all,
I'm assisting on a RED-based feature for which no Cinema Tools database was made initially. Now we're locking picture, and I need to create a database from which I can eventually create change lists for my audio and color houses.
Question is: how do I create a database at this stage of the edit, and how can I ensure everything links up properly once I do? I have read the whitepaper, looked at the Kadner book, etc., and I literally cannot find an answer to some basic questions, like:
-these files I'm told to 'drag into the database' - um, just to confirm, these are the original RED files, right? Not the ProRes files we've actually been editing with?
-is it just one database for the whole project, regardless of which reel I'm making change lists for? Or a database per reel?
-there will certainly be changes to all these reels after turnover, and reel names will be changed as a result. Everything I read says not to do that. For real? What's the alternative?
All the footage was initially transcoded to ProRes422, and I believe it was all done using RedCineX.
I know that's a lot. I'm quite new to this, and I appreciate any advice you can throw my way! (Mind you, I'm extremely new to Cinema Tools generally - so no answer is too basic!)
Noah Kadner
Re: Basic questions about FCP, RED, and Cinema Tools
on Aug 17, 2011 at 5:47:25 am
Why would CinemaTools come into the mix? You should be onlining from the original media- no?
Noah
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Panasonic GH2 and GoPro HD Hero.
Kathryn Cates
on Aug 17, 2011 at 12:01:05 pm
Hi Noah,
Onlining from the original media, yes. My goal here is to create a database so I can output change lists for my online guys, as they will be working while we are continuing to edit.
