Cutting in FCP need to deliver 4K files to After Effects
COW Forums : RED Camera
Jeffrey Lonigro
on Jul 28, 2011 at 5:05:05 pm
I'm cutting a :30 second spot shot on RED & all green screen. I assume I will Log & Transfer to a standard ProRes codec and cut the spot in the 2K format. Once the cut is approved I need to deliver a 4K version to my AE guy who will be doing extensive compositing. How best to make this happen? Do I need to use Cinema Tools?
David Battistella
Re: Cutting in FCP need to deliver 4K files to After Effects
on Jul 28, 2011 at 6:08:26 pm
I would:
Relink to the R3D's after the cut is locked using the Clipfinder workflow.
- Export the sequence to Apple Color.
- Set Apple color to output DPX files with one second handles
- Set the RED TAB to RED COLOR 2, RED GAMMA 2
By doing this each shot will be a DPX sequence in it's own FOLDER. Your AE GUY can bring in whatever shot he wants as a DPX file, do his thing and sent it back to you however you want it.
David
______________________________
The shortest answer is doing.
Lord Herbert
http://vimeo.com/battistella
Jeremy Garchow
on Jul 29, 2011 at 5:17:58 am
If you use log and transfer, then Automatic Duck your sequence to AE, the files will reconnect to the r3d if you have that option checked in prefs.
Stuart Ferreyra
on Jul 29, 2011 at 6:22:14 am
I am working on a very nicely shot RED short film that has 45% of green screen shots for compositing and video FX. To get the most quality and the cleanest key for the green screens we are delivering 16bit TIFF sequences that can be rendered to a wide variety of formats for the final online and finishing. Then we will deliver 2K 4444 files, HDCam, Blu-Ray and (possibly) HDCam SR masters to the client.
Stuart Ferreyra
Professional Colorist, Finisher, Online Editor.
http://www.timecodemultimedia.com
TIMECODE MULTIMEDIA
- Professional, Affordable Post Production for Indies.
- ProTools 9 Sound Design, Sound Editing and Sound Mixing.
- Color Grading, Finishing and Mastering for TV and Film.
- DaVinci Resolve, Apple Color / SD, HD, SR, RED, ALEXA, DSLR.
- SD, HD, SR Deck Rentals + Edit and Finishing Suites Rentals.
Jeffrey Lonigro
on Jul 29, 2011 at 3:47:22 pm
Confused about this part.
Where is that set?
David Battistella
on Jul 29, 2011 at 4:35:14 pm
If you are looking at r3d files in APPLE COLOR then there is a RED TAB that allows you to set ISO, COLOR SPACE and GAMMA and other RED metadata settings.
David
Lord Herbert
Jeremy Garchow
on Jul 29, 2011 at 5:11:57 pm
[David Battistella] "If you are looking at r3d files in APPLE COLOR then there is a RED TAB that allows you to set ISO, COLOR SPACE and GAMMA and other RED metadata settings. "
Must have the latest FCS Red installer for RC2 and RG2:
https://www.red.com/support/all/downloads/9/release_history
Jeremy
David Battistella
on Jul 29, 2011 at 6:35:45 pm
[Jeremy Garchow] "Must have the latest FCS Red installer for RC2 and RG2:
Jeremy"
thanks for having my back Jeremy. Forgot about that.
David
Lord Herbert
