REDCINE-X import problem
COW Forums : RED Camera
bruno silva
on Jul 27, 2011 at 7:17:01 pm
I setup some footage to import using recinex. I came across a problem when the last 2 rolls came in as all black video. I found the first clip to have an issue and it play normal for a few secs then turns black. Every clip is black after that one.
I re-imported and the same error occurred at the same exact time.
David Battistella
Re: REDCINE-X import problem
on Jul 29, 2011 at 6:36:55 pm
Try resetting the meta data.
Also,
try to set a look on one clip or try to apply a preset to one of the clips, see if it shows up.
David
______________________________
The shortest answer is doing.
Lord Herbert
http://vimeo.com/battistella
