Redcine-x export only half of clip
COW Forums : RED Camera
Mark Legg
on May 22, 2011 at 10:05:44 pm
Trying to make proress files from redcine x. All files worked fine but there is one shot that only exports half of the clip. The qt proxy files and the r3d plays all the way though in the viewer but every time I export this one clip it says 100% compete but half way through the clip half of it cuts to black and the rest of it is missing. I've tried clip finder and also have the same issue. The clip is 4min and no matter how I export it to create offline files the clip cuts the black at the 2min mark.
Could this be an error with the footage? The original files from the camera seem to play fine, it just doesn't want to turn into an offline file.
Anyone seen this before or have any suggestions to make something to work with so I can edit?
Thank you
Noah Kadner
Re: Redcine-x export only half of clip
on May 23, 2011 at 1:14:47 am
Sounds like a spanned clip- try opening in Red Cine X and make sure you have all RDM folders on the hard drive.
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Panasonic GH2 and Canon 7D.
© 2018 All Rights Reserved
