Epic continuous run-time at 120 fps
COW Forums : RED Camera
Harry Dawson
on May 20, 2011 at 9:40:47 pm
Wondering if I can get 4K at 120fps for 20 minutes continuous run-time on
the Epic with whatever recording machine is available.
David Battistella
Re: Epic continuous run-time at 120 fps
on May 20, 2011 at 10:31:12 pm
Dan,
I am going to say yes on a 256GB SSD recording media.
Why I said yes.
1. at a lower compression rate shooting 2:1 4K you can get up to 93 minutes on a 128GB SSD@24fps.
There is some math to be done but at a 12:1 compression ratio if you are willing to shoot 2:1 the you could get around 93 minutes, that equals 133920 frames.
at 120 FPS it means you could get about 18.6 minutes of 120FPS on a 128GB mag, on a 256 you could get about twice as much.
So I think the answer is yes provided you capture 4K 2:1 at a 12:1 compression ratio.
David
Why not do it today?
Graeme Nattress
on May 20, 2011 at 11:29:58 pm
A 256GB should indeed cope at a reasonable compression ratio.
Graeme
- http://www.nattress.com - Film Effects and Standards Conversion for FCP
