Working with Red One Camera files on FCP
COW Forums : RED Camera
Enric Junoy
on Mar 17, 2011 at 11:08:37 am
I wonder if someone could tell me if I should know anything special about working with Red One Camera files on FCP, or should I assume that as long as they are QT mov files is ok. Thanks
Enric
Jason Myres
Re: Working with Red One Camera files on FCP
on Mar 17, 2011 at 5:24:56 pm
FCP only supports frame sizes up to 2K, so you can either use the camera generated proxies, or more often, transcode the full-resolution 4K R3Ds to ProRes for editing, and then keep the originals if you need to online later. Many times though, people just output from ProRes to tape or to a deliverable like H.264.
Go here... https://www.red.com/support
and get RedCine-X if you need to start transcoding R3D files, and install the Final Cut Studio Installer if you want to open R3D in FCP, Color, or Quicktime.
Here is another thread that might help as well:
http://forums.creativecow.net/thread/242/4532
JM
