REDCINE to Color
COW Forums : RED Camera
Rinny Wilson
REDCINE to Color
on Mar 9, 2011 at 11:51:39 pm
I heard that there is a way to do this without exporting a quicktime from redcine. Basically what I want to do is adjust the ISO in redcine and then pull it into color. Is there any way I can do this, or do I need to make a quicktime from redcine?
Jeremy Garchow
Re: REDCINE to Color
on Mar 10, 2011 at 1:48:18 am
Why not just adjust the ISO in Color?
Rinny Wilson
on Mar 10, 2011 at 2:59:45 am
I've never used color before, and a friend mentioned that he did a similar process as I described above. I'll have to try it in color and see if the result is similar.
Jeremy Garchow
Re: EDCINE to Color
on Mar 10, 2011 at 4:12:26 pm
Make sure to download the latest FCS support from red.com/support. Once you get your timeline over to Color you will see a Red tab in the primary in room that allows adjusting of red metadata, including ISO.
Jeremy
Rinny Wilson
Re: EDCINE to Color
on Mar 10, 2011 at 11:39:32 pm
Thank you! As it turns out my friend exported out of redcine and didn't explain clearly. But this sounds like a better workflow to me.
Jeremy Garchow
Re: EDCINE to Color
on Mar 11, 2011 at 12:55:10 am
You need to be matched back to the R3ds in order to acces the red metadata in Color.
