FCP L&T Reel Info
COW Forums : RED Camera
Dan Wolfe
FCP L&T Reel Info
on Oct 11, 2010 at 12:17:16 am
just finished a shoot with AVCHD cams, P2 cams and a RED. I made sure to set all the clocks correctly on every camera including the RED and and all the offloading was done using ShotPut Pro. all of the AVCHD and P2 is importing correctly with the reel being whatever the folder name is that I gave it in SPP. the date and time is also correct. with the RED however, the reel name is the coming in as the clip folder and not the named drive which I designated in SPP. also, the RED isn't coming in with the correct time when I'm absolutely sure I set the clock correctly. not the end of the world but any ideas?
