R3D Timecode and Premiere Pro CS5
COW Forums : RED Camera
Richard Castlebury
on Sep 21, 2010 at 5:13:35 pm
If I open the R3D in the source monitor, its timecode entry is two frames late. For example, if the absolute timecode of the clip is 19:43:15:16, the source monitor will display 19:43:15:18. It's messing up my EDLs
Anyone know why?
Thanks.
Noah Kadner
Re: R3D Timecode and Premiere Pro CS5
on Sep 21, 2010 at 7:15:43 pm
What's the frame rate- and have you asked on the Premiere forum or RED's tech support board? Sounds iffy.
Noah
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Canon 5D Mark II and 7D.
Richard Castlebury
on Sep 21, 2010 at 7:28:05 pm
29.97 30fps Drop Frame
Not sure what Iffy means, but I'm simultaneously asking on RED's and Premiere's forums!
Noah Kadner
on Sep 21, 2010 at 9:10:12 pm
Perhaps your sequence settings don't match your source footage- drop frame- hmm really? Typically with RED it's non-drop frame.
Noah
Richard Castlebury
A thousand words
on Sep 21, 2010 at 9:58:22 pm
Hi Noah,
I appreciate your help.
I've tried a few times. Each time the sequence is Adobe's default Premiere Pro CS5(5.0.2) Red 4.5k 29.97.
The source footage is Red 4.5k 29.97.
The clip duration is ~7min.
You say that RED's R3Ds are typically NDF, which was my understanding, but if I switch the source view to timecode>NDF it's waaay off. Like not just two frames. Please take a look at the attached photo.
Anyway, how could DF or NDF or anything else, even 24p vs 30p cause a 2 frame difference over this duration???
It can't. So?
Richard Castlebury
on Sep 21, 2010 at 10:04:00 pm
Sorry, I'm not sure why the photo didn't work last time...
Richard Castlebury
on Sep 21, 2010 at 10:19:57 pm
Here's choosing to display Non Drop Frame in the source viewer:
Richard Castlebury
on Sep 22, 2010 at 9:13:42 pm
From After Effects CS5:
Richard Castlebury
on Sep 22, 2010 at 10:15:14 pm
