Color correcting footage
COW Forums : RED Camera
stan welks
on Jun 16, 2010 at 1:59:36 am
Can RED footage be color corrected in the program Color that comes with the Final Cut Studio, or should it be done professionally? If it should not be done in Color, what are the limitations of using this program to do this?
David Battistella
Re: Color correcting footage
on Jun 16, 2010 at 2:21:12 am
Yes,
You can Color COrrect RED native r3d footage, in Apple color using the full 12 bit debayer from the original r3d material.
Color is a professional grading app used by professional Colorists every day.
THe limitations are the same for any color project.
Keep the reel lengths short (22 minutes)
Does not work too well on speed shots.
There is a spanned clip error on some red clips which is easily solved with a freeware software.
It does not color correct still store shots from FCP.
David
Peace
cow
Uli Plank
on Jun 16, 2010 at 6:26:42 am
To make it a bit more clear: speed changes shot in the RED are fine, only ramped speed changes from FCP can be trouble (constant is OK).
Director of the Institute of Media Research (IMF) at Braunschweig University of Arts
